# feb/18/2022 21:01:09 by RouterOS 6.49.3
# software id = JTTU-4HZJ
# model = CCR1036-8G-2S+
# serial number = D8370D266F46
add name=BRV724
set [ find default-name=ether1 ] comment=TV speed=100Mbps
set [ find default-name=ether2 ] comment=DLINK speed=100Mbps
set [ find default-name=ether3 ] disabled=yes speed=100Mbps
set [ find default-name=ether4 ] disabled=yes speed=100Mbps
set [ find default-name=ether5 ] comment=zyra speed=100Mbps
set [ find default-name=ether6 ] disabled=yes speed=100Mbps
set [ find default-name=ether7 ] disabled=yes speed=100Mbps
set [ find default-name=ether8 ] comment="k"
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no comment=WAN \
mac-address=B8:69:F4:BA:0F:B7 speed=1Gbps
set [ find default-name=sfp-sfpplus2 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full \
comment=OLT
/interface vlan
add interface=sfp-sfpplus2 name=V2 vlan-id=2
add interface=sfp-sfpplus1 name=V724 vlan-id=724
add interface=sfp-sfpplus2 name=V724-OLT vlan-id=724
add name=wan
/ip hotspot profile
add name=pppoe-expired ranges=172.16.172.1-172.16.172.254
add name=pppoe-mikrotik ranges=10.2.2.2-10.2.2.254
add name=dhcp_pool8 ranges=192.168.50.10-192.168.50.254
add name=vpn ranges=10.254.10.2-10.254.10.254
add name=pppoe-tv ranges=10.100.101.1-10.100.101.254
add name=pppoe-net ranges=\
10.1.0.1-10.1.0.254,10.1.1.1-10.1.1.254,10.1.2.1-10.1.2.254
add name=dhcp_pool14 ranges=192.168.99.2-192.168.99.254
add address-pool=dhcp_pool8 disabled=no interface=ether5 name=dhcp1
add address-pool=dhcp_pool14 disabled=no interface=ether1 name=dhcp2
pppoe-mikrotik
/queue simple
add max-limit=10M/20M name=queue4pl target=192.192.1.2/32
/snmp community
set [ find default=yes ] addresses=192.168.50.0/24
/system logging action
set 0 memory-lines=10000
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=BRV724 interface=V724
add bridge=BRV724 interface=V724-OLT
set discover-interface-list=!wan
/interface detect-internet
set wan-interface-list=wan
/interface l2tp-server server
set default-profile=vpn enabled=yes ipsec-secret=user123456 use-ipsec=\
required
add interface=sfp-sfpplus1 list=wan
/interface pppoe-server server
add disabled=no interface=ether2 keepalive-timeout=30 service-name=ether2
add interface=ether4 keepalive-timeout=60 one-session-per-host=yes \
service-name=service3
add disabled=no interface=ether8 keepalive-timeout=30 service-name=\
"ether8-kulla "
add disabled=no interface=sfp-sfpplus2 keepalive-timeout=30 service-name=\
service2
add disabled=no interface=V2 keepalive-timeout=30 service-name=Vlan2
add address=192.168.4.1/24 comment="kulla " interface=ether8 network=\
192.168.4.0
add address=192.168.2.1/24 interface=ether2 network=192.168.2.0
add address=192.168.5.1/24 interface=V2 network=192.168.5.0
add address=192.168.50.1/24 interface=ether5 network=192.168.50.0
add address=192.168.8.1/24 interface=ether2 network=192.168.8.0
add address=10.10.10.1/30 interface=ether2 network=10.10.10.0
add address=192.168.3.1/24 interface=ether2 network=192.168.3.0
add address=192.168.99.1/24 interface=ether1 network=192.168.99.0
add address=(public IP).145.4/29 interface=sfp-sfpplus1 network=(public IP).145.0
add address=192.168.74.1/24 interface=sfp-sfpplus2 network=192.168.74.0
add address=(public IP).145.196 interface=sfp-sfpplus1 network=(public IP).145.196
add address=192.192.1.1/24 interface=sfp-sfpplus2 network=192.192.1.0
/ip arp
add address=10.13.37.254 comment="degert " interface=ether4 mac-address=\
74:4D:28:4E:D8:EB
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.99.2 client-id=\
ff:b6:22:f:eb:0:2:0:0:ab:11:dc:32:3e:5e:6b:95:a4:76 mac-address=\
00:23:24:A6:90:FF server=dhcp2
add address=192.168.50.0/24 gateway=192.168.50.1
add address=192.168.99.0/24 gateway=192.168.99.1
set allow-remote-requests=yes cache-max-ttl=2h cache-size=20048KiB servers=\
(public IP).145.4,8.8.8.8
/ip dns static
add address=192.168.77.2 name=pup.mine.nu ttl=30m
/ip firewall address-list
add address=(public IP).145.0/24 list=tt
add address=(public IP).146.0/23 list=tt
add address=192.168.77.2 list=prxy
add address=(public IP).145.40 list=prxy
add address=192.168.99.2 list=ts
add address=(public IP).146.71 list=ts
add address=(public IP).147.109 list=ts
add address=(public IP).144.10 list=ts
add address=(public IP).147.91 list=ts
add address=(public IP).146.1 list=ts
add address=(public IP).145.66 list=ts
add address=(public ip).32.0/20 list=145
add address=(public ip).64.0/20 list=145
add address=(public ip).172.0/22 list=145
add address=(public ip).0.0/21 list=145
add address=(public ip).128.0/20 list=145
add address=(public ip).48.0/21 list=145
add address=(public ip).96.0/20 list=145
add address=(public ip).32.0/22 list=145
add address=(public IP).146.0/24 list=145
add address=(public ip).76.121 list=145
add address=(public IP).146.71 list=tt
add address=(public IP).144.8 list=tt
add address=(public IP).147.109 list=tt
add action=drop chain=forward comment="porte qe perdoret vetem nga viruset()" \
dst-port=445 protocol=tcp
dst-port=135,137-139,27374,1080,3127-3128 protocol=tcp
dst-port=135,137-139,69,514,161-162,6660-6669 protocol=tcp
add action=drop chain=forward comment="()" dst-port=22,2222 in-interface=\
sfp-sfpplus1 protocol=tcp src-address=!(public IP).144.0/22
add action=drop chain=forward comment="()" dst-port=21-25 out-interface=\
add action=drop chain=input comment="()" dst-port=8000 in-interface=\
add action=drop chain=input comment="()" dst-port=53 in-interface=\
sfp-sfpplus1 protocol=udp
"mos e fshi, ndal abuzimin me web proxy nga bota()" dst-port=8080 \
in-interface=sfp-sfpplus1 protocol=tcp
add action=accept chain=forward comment="()" dst-address=(public IP).145.17
add action=fasttrack-connection chain=forward comment="tv " \
src-address-list=ts
dst-address-list=ts
add action=drop chain=forward comment="drop kliente" out-interface=\
sfp-sfpplus1 src-address=172.16.172.0/24
add action=drop chain=forward comment="jo internet per antenat()" \
out-interface=sfp-sfpplus1 src-address=192.168.3.0/24
add action=drop chain=forward comment="kliente" dst-address-list=ts \
log=yes src-address=10.0.0.0-10.1.2.255
add action=fasttrack-connection chain=forward dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward dst-port=53 protocol=udp
add action=src-nat chain=srcnat out-interface=ether1 to-addresses=\
192.168.99.1
add action=src-nat chain=srcnat comment="nat 2" dst-address=(public IP).144.0/22 \
out-interface=sfp-sfpplus1 to-addresses=(public IP).145.72/29
add action=src-nat chain=srcnat comment="nat 2" out-interface=sfp-sfpplus1 \
src-address=10.0.0.0/8 to-addresses=(public IP).145.72/29
src-address=192.168.0.0/16 to-addresses=(public IP).145.72/29
src-address=172.16.0.0/12 to-addresses=(public IP).145.72/29
src-address=192.192.1.0/24 to-addresses=(public IP).145.72/29
add action=dst-nat chain=dstnat comment="kalim" dst-address=\
(public Ip).116.250 dst-port=3000,25461 protocol=tcp to-addresses=\
(public IP).146.72 to-ports=8000
add action=dst-nat chain=dstnat dst-address=(public IP).145.4 dst-port=25461 \
protocol=tcp src-address-list=tt to-addresses=192.168.99.2 to-ports=25461
add action=dst-nat chain=dstnat comment=vps dst-address=(public IP).145.4 \
dst-port=3389 protocol=tcp to-addresses=192.168.50.3 to-ports=3389
dst-port=86 protocol=tcp to-addresses=192.168.50.3 to-ports=85
add action=dst-nat chain=dstnat dst-address=(public IP).145.4 dst-port=4033 \
protocol=tcp src-address-list=tt to-addresses=192.168.99.2 to-ports=4033
add action=redirect chain=dstnat dst-address-list=prxy dst-port=85 protocol=\
tcp to-ports=8080
add action=dst-nat chain=dstnat comment=Kamera. dst-address=(public IP).145.4 \
dst-port=34568 protocol=tcp to-addresses=192.168.50.29 to-ports=34567
add action=dst-nat chain=dstnat comment="The Dude" dst-address=(public IP).145.4 \
dst-port=81 protocol=tcp to-addresses=192.168.50.3 to-ports=81
add action=dst-nat chain=dstnat comment="user" dst-address=\
(public IP).145.4 dst-port=8099 protocol=tcp to-addresses=10.200.200.2 \
to-ports=8000
(public IP).145.4 dst-port=8014 protocol=tcp to-addresses=10.200.200.14 \
to-ports=8014
(public IP).145.4 dst-port=37777 protocol=tcp to-addresses=10.200.200.3 \
to-ports=37777
(public IP).145.4 dst-port=8001 protocol=tcp to-addresses=10.200.200.4 \
to-ports=8001
add action=dst-nat chain=dstnat comment="user " dst-address=\
(public IP).145.4 dst-port=8009 protocol=tcp to-addresses=10.200.200.5 \
to-ports=8009
add action=dst-nat chain=dstnat comment="user" \
dst-address=(public IP).145.4 dst-port=8007 protocol=tcp to-addresses=\
10.200.200.7 to-ports=8000
(public IP).145.4 dst-port=8008 protocol=tcp to-addresses=10.200.200.8 \
to-ports=8008
(public IP).145.4 dst-port=8006 protocol=tcp to-addresses=10.200.200.10 \
to-ports=8000
add action=dst-nat chain=dstnat comment="user" dst-address=(public IP).145.4 \
dst-port=8012 protocol=tcp to-addresses=10.200.200.12 to-ports=8012
dst-port=82 protocol=tcp to-addresses=192.168.8.100 to-ports=80
dst-port=443 protocol=tcp to-addresses=192.168.8.100 to-ports=443
add action=masquerade chain=srcnat dst-address=192.168.8.100
dst-address=(public IP).145.4 dst-port=8081 protocol=tcp to-addresses=\
10.200.200.13 to-ports=8081
/ip proxy
set enabled=yes
/ip proxy access
add action=deny dst-address=(public IP).145.40 dst-port=85 path=/digi/c/ \
redirect-to=xtv.anondns.net:8000/c/
add action=deny dst-address=192.168.77.2 dst-port=85 redirect-to=\
add distance=1 gateway=(public IP).145.6
add distance=1 dst-address=(public IP).144.1/32 gateway=(public IP).145.6 scope=10
add distance=1 dst-address=(public IP).145.72/29 type=blackhole
add check-gateway=ping distance=1 dst-address=192.168.77.2/32 gateway=\
(public IP).145.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=34
set ssh disabled=yes
set api disabled=yes
set winbox port=32
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd
set time-interval=hour
/ppp aaa
set interim-update=9m use-radius=yes
/ppp l2tp-secret
add address=30.0.0.0/24 secret=user321
/radius
add address=(Public IP).76.121 comment=ndize secret=user1 service=ppp src-address=\
(public IP).145.4 timeout=3s
add address=144.91.76.121 comment=ndize secret=user1 service=ppp src-address=\
(public IP).144.231 timeout=3s
/radius incoming
set accept=yes port=1700
/snmp
set contact=user location=tr trap-generators=interfaces trap-interfaces=\
all
/system clock
set time-zone-name=Europe/Tirane
/system identity
set name=BOX
/system resource irq rps
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
/system scheduler
add interval=30m name=schedule1 on-event=\
"/ip firewall filter remove [find action=jump]" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=feb/18/2021 start-time=18:05:39
add interval=14w2d name=schedule2 on-event="/system reboot\r\
\n" policy=\
start-date=feb/25/2021 start-time=05:00:00
/tool graphing interface
add allow-address=192.168.50.0/24 interface=sfp-sfpplus1
add allow-address=192.168.50.0/24 interface=ether1
If someone can help me i can give access with teamviwer or anydesk … lodi.artimg@gmail.com , thank you .
