CCR1036-8G-2S+ update problem
Hi
I have a problem with the CCR1036-8G-2S+ update.
Regardless of whether it is an automatic or manual update.
There is software version 6.43.2 on MT.
I want to update but it fails.
When in System > Package List > Check for Updates I select the “current” channel, it shows the latest version 6.49.7.
Then click Download and Install.
The router will download the file and restart. After turning on the device, it is still version 6.43.2. There is no error in the logs, and there is still a file with version 6.49.7 in Files.
When I want to update to 7.7 it doesn’t download the update file. There is a break.
Internet access is available, DNS has been introduced. There is also a ping to the mikrotik website.
What can I do to update?
