CCR1036 and high CPU temperature
using CCR1036 for years and somehow, “normal idle” CPU temp keeps rising. Today’s operating temp is 62°C, after I re-attached the stock black heatsink with TWO 80mm Noctua fans blowing directly onto heatsink (currently, chassis is open). Stock fans (2x 40mm 10k rpm) were just TOOO noisy, even at lower rpm (around 4-5k rpm).
Before installing back the stock heatsink, I used custom heatsink block with heat pipes for cooling (temp was even higher, around 68-70°C). Also added 80mm Noctua fans outside the chassis to the heatink fins - why?
Years ago, when I first added 80mm fans directly to heatsink, I could lower CPU temp down to 40°C.
Today, this is NOT possible.
Anyone observed the same behavior with TileGX CPUs? Idle CPU temperature getting higher and higher?
Regards,
R.
That change will be correlated with something, but you don’t give a lot of detail to make solid guesses with. I hope you will be content with vague guesses. :wink:
Key fact: semiconductor operating temperature is always relative to ambient temperature. The first prerequisite to a steady operating temperature, therefore, is a steady ambient temperature. Is that the case?
If everything around the router is getting hotter (e.g. higher load on nearby equipment, higher air conditioner set-point, global warming, etc.) the router will naturally get hotter even if nothing else changes within it.
Instead of saying 62°C, it would be more useful in a situation like this to say instead something like “38°C over ambient.” That requires making two temperature measurements, the other being out in the room, well away from the major heat generators. Doing this allows you to make comparisons against this variable over time. If you find that your historical 22°C rise correlates with a 20°C rise in ambient temperature, you know 2°C at most are inherent to the router itself.
Did you refresh the heat sink compound, or did you reuse what was there before?
If you refreshed it — as you should have done — then did you clean the old stuff off first? If so, how? How much fresh compound did you use?
That isn’t necessarily best for cooling. Fans work by developing 𝚫P to move air. If you dissipate their force in all directions outward from the PCB, they will necessarily move less air over some areas of the PCB. There’s only so much pressure to go around.
I’ve used equipment that ran perfectly fine when the covers were closed, but would shut down due to overheating if you opened it up while it was running.
It’s only possible for what you’ve done to help if the router’s designers did a bad job of modeling the internal airflow, so that opening the whole thing up to ambient air gives a better overall result. This is by no means certain. A lot of hardware design shops buy and use expensive thermal design software for this purpose. You might’ve wrecked months of careful airflow design with that move.
Since you speak of opening the router up, can I assume you’ve thoroughly dusted the router’s innards? If not, that’s an insulating blanket that will accumulate, contributing to rising operating temperatures.
2×80 may not be equivalent in 𝚫P if the new ones run slow enough. That doesn’t explain the steadily rising temperature you report, but it would explain an initial step change. What did you observe?
Aside from the above guesses, what else has changed between then and now?
Have you upgraded RouterOS over that span? Different software can change operating temperature by putting more background processes into play to deliver new functionality. New software can also take more CPU power to deliver the same functionality in a better manner; ROS 7 is known to do that, though you’d see a one-time step change here, not the steady rise you report.
You’ve spoken of “idle” conditions, but is the router truly idle? If you have a background data flow through the router, and that background load has changed over time, it could explain this. For example, you might have security cameras constantly streaming to an NVR somewhere, and you’ve learned to disregard them as part of the system’s “noise floor,” but you’ve neglected to consider that all of the old 720p cameras have been replaced first with 1080p cams, then 4k, doubling bandwidth requirements each time.
Ya canna move packets without moving electrons, and ya canna move electrons without generating heat.
maybe measurement point have changed in RouterOS
ccr1036 have gone through several revisions in latest years maybe some hardware change on temp measurement hapened
maybe exhaust fan profiles have changed reducing noise but increasing temperatures
around 60-65 °C are not a worry temperature for nowadays electronics
Hello guys, tnx for quick response.
My first entry was a bit of a mess, I guess I did not re-read it before posting. :frowning:
Then, I missed the edit window and couldn’t edit it anymore.
Regarding room (environment) temperature: router resides in my work office, mounted to the wall, so a lot of “breathing room” for it. AC is set to 25°C, but if room is vacant, room temp CAN get up to 30°C. That is it. But, it is a BIIIIIGG room, so even without running AC, it is not exactly toasty in here. Ever.
Regarding “idleing”: mostly 2-4 CPUs reporting 1-5% load, very short spikes to about 10-20% when doing an full download (@500Mbps), and that is it.
CCR is running (almost) last 6.x firmware (v6.48.1).
Reported “temperature”: jumping between 43°C and 50°C (which is a a BIT high, in “early years”, this was usually 30°C)
Reported “cpu-temperature”: jumping between 62-64°C.
Two (2x) 80mm Noctua fans running at ~1400rpm. The heat sink IS not even lukewarm to the touch.
I do repaste every time I take the heatsink off, clean it with isoprop and apply new paste (using Coolmaster and MX4 brand).
In the begining (when CCR was brand new), blowing with two fans directly onto heatsink lowered the reported “env” temp to 30°C, and CPU was around 40°C.
Later, with heatsink block and heat pipes, temp did rise to 50°C without fans.
I personally haven’t yet met a CPU that would increase its operating temp in such a way, so I am asking a broader audience. :slight_smile:
This is resources report from the router:
Uptime 1d 04:07:53
Free Memory 3517.3 MiB
Total Memory 3968.0 MiB
CPU tilegx
CPU Count 36
CPU Frequency 1200 MHz
CPU Load 0 %
Free HDD Space 896.7 MiB
Total HDD Size 1024.0 MiB
Architecture Name tile
Board Name CCR1036-8G-2S+
Version 6.48.1 (stable)
Build Time Feb/03/2021 10:54:22
And this is my status view for temp & fans:
Name cpu-temperature
Value 62 C
Name temperature
Value 43 C
FAN1 1417 RPM
FAN2 1377 RPM
