The router was received with ROS 6.2 and we upgraded to 6.4 but the problem remains…
MikroTik 6.4
WAN_ROUTER Login:
MikroTik 6.4
WAN_ROUTER Login:
at virtual address 0x0000000000000000, pc cpu_idle+0x140/0x2b8
Pid: 0, comm: swapper/14, CPU: 14
Unable to handle kernel NULL pointer dereference
r0 : 0xfffffff5000e096c r1 : 0xfffffff5000e0848 r2 : 0x000006cac6e97ccf
hrtimer: interrupt took 30948941 ns
r3 : 0x0000000000000000 r4 : 0xfffffe007c385978 r5 : 0xfffffe00736cfc04
r6 : 0xfffffe00006e2540 r7 : 0x0000000000000000 r8 : 0x0000000000000000
r9 : 0x0000000000000000 r10: 0x0000000000000000 r11: 0xfffffff5000e0900
r12: 0x000001f4ffba0000 r13: 0x0000000000000000 r14: 0x0000000000000000
r15: 0x0000000000000000 r16: 0x666666666666679f r17: 0x0000000000000040
r18: 0x0000000000000080 r19: 0xfffffe00736cfa18 r20: 0xfffffe007c49fed0
r21: 0xfffffe007c49ff10 r22: 0xfffffe007c49fed8 r23: 0xfffffe007c49ff18
r24: 0xfffffe007c49fee0 r25: 0xfffffe007c49ff80 r26: 0xfffffe007c49ff40
r27: 0xfffffe007c49ffa0 r28: 0xfffffe007c49ffa8 r29: 0xfffffe007c49ffb0
r30: 0xfffffe0000540040 r31: 0xfffffe0000540080 r32: 0x0000000000000000
r33: 0x0000000000000000 r34: 0x0000000000000000 r35: 0x0000000000000000
r36: 0x0000000000000000 r37: 0x0000000000000000 r38: 0x0000000000000002
r39: 0xfffffff5000e0878 r40: 0x0000000000020000 r41: 0xfffffe007c49fea0
r42: 0xfffffff7000a8e30 r43: 0xfffffe007c49fec8 r44: 0x0000000000000000
r45: 0x000001f4ffba0000 r46: 0x0000000000000000 r47: 0xfffffe007c49ff30
r48: 0xfffffff5000e0848 r49: 0x000000000000000e r50: 0xfffffe007c49ff30
r51: 0xfffffe0000555ce8 r52: 0x0000000000000000 tp : 0x000001f4ffba0000
sp : 0xfffffe007c49ffb0 lr : 0xfffffff700029cd8
pc : 0xfffffff700029ce0 ex1: 1 faultnum: 18
Starting stack dump of tid 0, pid 0 (swapper/14) on cpu 14 at cycle
897213141846
8
frame 0: 0xfffffff700029ce0 cpu_idle+0x140/0x2b8 (sp 0xfffffe007c49ffb0)
frame 1: 0xfffffff700029cd8 cpu_idle+0x138/0x2b8 (sp 0xfffffe007c49ffb0)
Stack dump complete
—[ end trace 547095b6e05bca11 ]—
Pid: 0, comm: swapper/24, CPU: 24
r0 : 0xfffffff50018096c r1 : 0xfffffff500180848 r2 : 0x000006cacb11c314
r3 : 0x0000000000000000 r4 : 0xfffffe007c3892f8 r5 : 0xfffffe0073e2fc04
r6 : 0x0000000000000000 r7 : 0x0000000000000000 r8 : 0x0000000000000000
r9 : 0x0000000000000000 r10: 0x0000000000000000 r11: 0xfffffff500180900
Pid: 0, comm: swapper/13, CPU: 13
r0 : 0xfffffff5000d096c r1 : 0xfffffff5000d0848 r2 : 0x000006cac9e1df98
r3 : 0x0000000000000000 r4 : 0xfffffe007c3853b8 r5 : 0xfffffe0073e8fc04
r9 : 0x0000000000000000 r10: 0x0000000000000000 r11: 0xfffffff5000d0900
r12: 0x000001f4ffb90000 r13: 0x0000000000000000 r14: 0x0000000000000000
r18: 0x0000000000000080 r19: 0xfffffe0073e8fa18 r20: 0xfffffe007c48fed0
r21: 0xfffffe007c48ff10 r22: 0xfffffe007c48fed8 r23: 0xfffffe007c48ff18
r24: 0xfffffe007c48fee0 r25: 0xfffffe007c48ff80 r26: 0xfffffe007c48ff40
r27: 0xfffffe007c48ffa0 r28: 0xfffffe007c48ffa8 r29: 0xfffffe007c48ffb0
r36: 0x0000000000000000 r37: 0x0000000000000000 r38: 0xfffffe007c48fea8
r39: 0xfffffff5000d0848 r40: 0xfffffff5000d06c0 r41: 0xfffffff5000d0860
r42: 0x000000000000000d r43: 0xfffffff700082318 r44: 0xfffffe007c48fec8
r45: 0xfffffff5000d0848 r46: 0x0000000000000000 r47: 0xfffffe007c48ff30
r48: 0xfffffff5000d0848 r49: 0x000000000000000d r50: 0xfffffe007c48ff30
r51: 0xfffffe0000555ce8 r52: 0x0000000000000000 tp : 0x000001f4ffb90000
sp : 0xfffffe007c48ffb0 lr : 0xfffffff700029cd8
Starting stack dump of tid 0, pid 0 (swapper/13) on cpu 13 at cycle
897293151005
8
frame 0: 0xfffffff700029ce0 cpu_idle+0x140/0x2b8 (sp 0xfffffe007c48ffb0)
frame 1: 0xfffffff700029cd8 cpu_idle+0x138/0x2b8 (sp 0xfffffe007c48ffb0)
Stack dump complete
—[ end trace 547095b6e05bca12 ]—
Kernel panic - not syncing: Kernel page fault running the idle task!
897293160762
1
frame 0: 0xfffffff7004efe78 dump_stack+0x0/0x20 (sp 0xfffffe007c48fbf8)
frame 1: 0xfffffff7004e90b8 panic+0x168/0x3a8 (sp 0xfffffe007c48fbf8)
frame 2: 0xfffffff700038598 do_page_fault+0xa68/0xc78 (sp
0xfffffe007c48fca0)
frame 3: 0xfffffff7004f0128 handle_interrupt+0x1f0/0x208 (sp
0xfffffe007c48fd4
0)
<interrupt 18 while in kernel mode>
frame 4: 0xfffffff700029ce0 cpu_idle+0x140/0x2b8 (sp 0xfffffe007c48ffb0)
frame 5: 0xfffffff700029cd8 cpu_idle+0x138/0x2b8 (sp 0xfffffe007c48ffb0)
Stack dump complete
Pid: 0, comm: swapper/9, CPU: 9
r0 : 0xfffffff50009096c r1 : 0xfffffff500090848 r2 : 0x000006cacb13b0cd
r3 : 0x0000000000000000 r4 : 0xfffffe007c383cb8 r5 : 0xfffffe407dc3fc04
r9 : 0x0000000000000000 r10: 0x0000000000000000 r11: 0xfffffff500090900
r12: 0x000001f4ffb50000 r13: 0x0000000000000000 r14: 0x0000000000000000
r18: 0x0000000000000080 r19: 0xfffffe407dc3fa18 r20: 0xfffffe007c44fed0
r21: 0xfffffe007c44ff10 r22: 0xfffffe007c44fed8 r23: 0xfffffe007c44ff18
r24: 0xfffffe007c44fee0 r25: 0xfffffe007c44ff80 r26: 0xfffffe007c44ff40
r27: 0xfffffe007c44ffa0 r28: 0xfffffe007c44ffa8 r29: 0xfffffe007c44ffb0
r36: 0x0000000000000000 r37: 0x0000000000000000 r38: 0xfffffe007c44fea8
r39: 0xfffffff500090848 r40: 0xfffffff5000906c0 r41: 0xfffffff500090860
r42: 0x0000000000000009 r43: 0xfffffff700082318 r44: 0xfffffe007c44fec8
r45: 0xfffffff500090848 r46: 0x0000000000000000 r47: 0xfffffe007c44ff30
r48: 0xfffffff500090848 r49: 0x0000000000000009 r50: 0xfffffe007c44ff30
r51: 0xfffffe0000555ce8 r52: 0x0000000000000000 tp : 0x000001f4ffb50000
sp : 0xfffffe007c44ffb0 lr : 0xfffffff700029cd8
panicSaver: dumping panic to flash
flash: prg 73
tile program flash offset:00073000 size:00001000
flash: prg 74
tile program flash offset:00074000 size:00001000
