Hello Forum
My first post is about Mikrotik Log-s
Our CCR displays logs with bugs, i think
For this moment they are seen logs of Dec 26 and Dec 27 (they are like static and unfortunately they are not deleting )
Besides, today’s logs are displayed at bottom 3 lines and i cant see, for example, the log of past 5 minute
Please not to tell me upgrading Mikrotik (now it’s 6.20 version)
Thank’s for attantion
You can remove this post
The problem was solved itself
Please describe how you solved it, maybe this helps others in future.
upgrade to the 6.27 version has helped
