Hi, we are using a CCR1036 RouterOS 6.6 as a PPPoE concentrator with simple queues for shaping. In the evening the number of online PPPoE connections reaches 1500. I started to notice that in the evening when the number of online PPPoE sessions exceeds 1000, clients’ throughput starts to degrade. Total throughput stays at 400-500 Mbit/s. CPU load does not exceed 20-30% but the CCR cannot go beyond 400-500 mbit/s.
Today I upgraded to 6.9 but I doubt it will make any difference. Has anyone experienced the same problem? What can be done apart from installing a second PPPoE concentrator and load balancing between them.
How did you check the CPU load? Is it the average load (from /system resource), or max load per core (from /system resource cpu)?
When the avg load is 30% - all cores can have 30%, but it’s also possible that 20 cores have 0% and other 10 have 100% - and that’s not good . Always check all the CPU cores. If any of them have 100%, the performance can start degrading…
Do you have dynamic simple queues or static? if dynamic, i would suggest to try out making them all static.
I noticed that removing and adding queues all the time results in performance degradation.
What other configuration do you have?
what does /tool profile menu says?
I observed the same behaviour with IPoE and PCQ queues - on 400-500 Mpbs clients begin to complain =( switched back to x86
seems like CCR is still not for shaping, while we’re successfully using them as simple firewall/policy routers at upto 2.5 Gbps and more (5 min average)
What other configuration are you guys running, i have ~700 customers on each of my boxes, though only around 140mbit at peak, dynamic queues, but my avg load is always at 0% on all cpu’s i mean once in a while one will spike for a half second to 10-20% but then back to 1-2%
I know you said the cap seems to be at 400mbit, but i just see something as odd that your load is so much higher than mine, you’d expect it to grow pretty consistently as bandwidth increases not exponentially. LOAD-IRQ-DISK all 0-1% on my box at 700 users…
Question when your not at that cap of 400+mbit, what does your CPU look like earlier in the day?
Also did you contact mikro support to see what they say?
Note i am on 6.24 as their were many CCR changes made between 6.9 and 6.24
