ccr1036 pure routing
we are receive a public /24 from our upstream routed on the ccr public ip and we have subnetted it into different /29 assigned to vlan:
router public ip: X.X.X.2/28 (eth1)
default gw: X.X.X.1
upstream send y.y.y.y/24 to X.X.X.2
we created a bridge (eth3 and eth4) and a lot of vlan, for example the first: y.y.y.1/29 vlan100
connecting a pc on vlan100 and assigning it y.y.y.2 it is reacheable from internet but internet sees it as X.X.X.2 (router public ip). we put a generic nat rule as is the only way we can ping internet from client pc.
there is a way to let use the pc public ip directly without nat ?
When you want to do pure routing you should NOT put in a NAT rule!
There probably is some config error in the router or in the PC (bad subnet mask, bad default gateway, etc). When you find it, it should just work.
you are right, this was the fault:
action=drop chain=forward comment=“Drop invalid” connection-state=invalid
by that all vlans traffic vs internet got dropped… disabled it and all works like a sharm!
