CCR1036 with USB wifi and micro sd card
Im trying to attach an AC wifi usb adapter to my CCR but i cant seem to get it working. When i look under resources and usb it detects and identifies the usb wifi but it doesnt show up under wireless. What exactly is required to get a usb wifi adapter working? Does it have to be in the supported list of adapters and cards? It also doesnt seem to detect the micro sd card. I previously used the card in my rb450G which worked but on the CCR there is no stores category and disks show nothing. I think the card is formatted in fat32. Its too bad it doesnt have usb3 to make full use of AC wireles or even a miniPCIe slot for that since the specs show the CPU has 20 PCIe lanes. Being able to attach PCIe cards would make this like some of the cisco or nortel switches or routers where you could add different modules to them.
Can the CCR support a usb hub and usb hard drive?
