I have a CCR1072-1G-8S+ that shows no sign of life at power-on. I removed the SPI NOR (Winbond W25X40, 512 KB) and read it with a programmer. The size is exactly 524288 bytes, and the read is consistent: the last 24 KB read back as 0xFF while the rest reads as 0x00, so this does not look like a stuck-at-zero reader.
Layout of what is on the chip:
- 0x00000–0x00024: a small header (non-zero), then zeros up to 0xFFFF
- 0x10000–0x10FFF: 4 KB of real data, the tail of a Tilera loader (same structure as the end of the first stage in tilegx-7_25.fwf: AAAAAAAA55555555 marker, section table, DEADBEEF, then a compressed stream), but from a different build than 7.25 (size word 0x20178 vs 0x221b8)
- 0x11000–0x79FFF: all zeros (including 0x40000, where a backup loader would be)
- 0x7A000–0x7FFFF: all 0xFF
So both bootloader copies are gone. have the tilegx .fwf from the RouterOS npk, but I can’t flash it as is because I don’t know the NOR layout (offsets, header at 0x0, main/backup copy placement).
Could anyone with a working CCR1072-1G-8S+ (or any CCR with the same board) dump the W25X40 and share the 512 KB .bin? Please mention the current RouterBOOT version if you know it. I understand the dump may contain unit-specific data (MAC/serial/hard config). If you know where those regions are, feel free to mask them; I only need the loader and the layout. I can also share my dump and the analysis if it helps anyone else.
Thanks!
