Had issue yesterday, Network DOWN, Cacti reported CPU 100% during outage, could not access router,
rebooted, all good… Was passing maybe 1.2 Gigs data.
Anyone else have this issue?
Never use 6.34.1. But Im using 6.34.2, and no having issue when having through put around 1.55gbps.
You do know the limit for a single flow for a Tilera powered box is a little bit over 1Gb/sec…
The way it works is 1 flow is forwarded by 1 CPU…
You’re going to have keep your individual flows at 1Gb/sec or lower. That being said though it shouldn’t make the box stop forwarding. That’s…different…
