CCR1072 Booting Failure , Firmware crush
This is ccr1072 as shown in the youtube , it dosent boot correctly it , still in this state and when i try to enter by console , the screen appears like corrupted system , it was working correctly before two months of the idle state , help please ?
https://www.youtube.com/watch?v=tg3uOfjjMcM
Netinstall ?
Yes, do a Netinstall so the NAND can be formatted. Likely just OS corruption.
Netinstall doesnt solve the problem .. the device appear in netinstall and we install the packages , but after reboot the same problem … one beep and loud voice from fans
Use a serial console cable and repartition and reformat the NAND. Make sure you reinstall the latest stable release.
