Tinkering with my 1072 here, and just put in a SanDisk 1TB SSD in the M.2 slot 0. The PCI sections in winbox seem to indicate it’s “there”, but unusable. I have already made a supout file, do you guys want it? Would looooove this to work soon.
greetings
I installed a crucial mx300 275gb m2 ssd on ccr1072, i’m having the same problem, it seems ccr1072 does not support pci-e 3.0 ssd.
is there any way to work around this problem? or must I change the ssd to another one that is compatible with ccr1072?
is there any list for supported ssd for ccr1072?
I have installed Plextor M8PeGN Pci-e 3.0 and it works ,
I set a datapath for user-man on it but its very very slow
I Have an SATA SSD Extrnal HDD and set the data path for UM on it and still slow Not like the normal speed for an SSD OR M.2 SSD Both in ( ext3 ) file format
normis do you find it more reliable to run user manager in AWS CHR (licence level free ) and make a tunnel for radius requests? or better local at a usb flash drive?
i want to be sure that there are no power outages that can corrupt user manager database .
Any news about a list of verified/working/compatible SSD’s. ?
Or at least hardware specifications ?
I install a M2.2280 XPG SX8200 Pro, NVMe 1.3, PCIe Gen3x4 SSD on a latest CCR1072-1G-8S+ (6.46.7 LTS) without success. https://www.xpg.com/en/feature/583/
