CCR1072 - Support S-RJ01
In the 6.34rc34 changelog I see this
“added support for S-RJ01 SFP modules”
Is still supported in the 6.33.3 without problem? (I don’t see it on changelog)
I’ve some CCR1072 and I need to say if it is supported in the stable release, because I need to use these in my core network
Regards
What’s new in 6.34rc34 (2016-Jan-08 10:04):
What’s new in 6.33.3 (2015-Dec-03 16:08):
6.33.3 do not supports s-rj01
and then, why testing with 6.33.3 work?
CCR recognize the module and data passthrough?
Sure that it is not just an omission of Mikrotik in the changelog?
Mikrotik? some idea?
good question
When using older ROS build than some of v6.34rcXX you might encounter some problems with S-RJ01. In these rc builds we have fixed those problems that CCR1072 had with S-RJ01 modules.
