Our CCR2004-16G-2S+ display fan speed as 0 RPM on both fan 1-2.
Board Temp1 is 35 C
Board Temp2 is 45 C
CPU Temp is 55 C
I'm wondering if it is normal or I should worry about it now?
Board Temp1 is 35 C
Board Temp2 is 45 C
CPU Temp is 55 C
Temperatures seem to be at proper levels so you should wait for higher load to see if fans would start to do their work.
If it is possible, check visually if they run or not. If both fans are stopped, the system cool enough, and no need to auxiliary cooling (via the fans)
