CCR2004-16G-2S+ no hosts on bridge ROS v7.11
I’ve come across an issue with my CCR2004-16G-2S+. Unfortunately, I can’t play around with tests too much since it’s already installed. Yesterday after I reconfigured it, it started to populate hosts, but today it’s blank again. Whenever I try to issue an export command, it blocks the export process. The error message is quite clear. I’ve attempted a factory reset and even added all interfaces to a single bridge, but the error persists: no hosts are being displayed under the bridge section. Has anyone else encountered a similar problem or found a solution?
Here the export fails with the test config
[admin@MikroTik] > export
# 1970-01-02 00:01:58 by RouterOS 7.11
# software id = ERV0-Y2NM
# model = CCR2004-16G-2S+
add name=bridge1
/port
set 0 name=serial0
set 1 name=serial1
#error exporting "/interface/bridge/host" (timeout)
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
/system note
set show-at-login=no
I have a CCR2004-16G-2S+ running v7.13 that also hangs when issuing “/interface bridge host export”. This is interfering with my configuration backup process.
[admin@router1] > /interface bridge host export
# 2024-01-23 10:19:44 by RouterOS 7.13
# software id = QAEW-I8M1
# serial number = HED08K83471
[admin@router1] > int bridge/host/
[admin@router1] /interface/bridge/host> print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
If reboot do not solve,
reload last working backup, install 7.13.2 and retry.
It’s not a configuration issue. We have four CCR2004-16G-2S+ routers on our network. Two of them intermittently are able to export/print the interface bridge host config, and the other two have less hosts connected to them but are very slow to export/print.
How many entries are there inside /interface bridge host?
On the two where the “/interface/bridge/host print” is simply slow, they have around 200 entries. On the other two, I can’t tell at the moment because of the “action timed out” message I posted above. I’m hoping it runs successfully soon.
In reality I was thinking of the internal configuration database being corrupt, rather than your mistake.
And I realized now that “How many entries are there inside?” could be misunderstood:
I meant how many static entries you added, not how many are present at the moment, including dynamic ones.
Have a nice day.
There are no static entries configured. An “export”, if it completes without a timeout, is just empty, as expected. Rebooting the router clears the issue for a few minutes, but then it goes back to timing out.
Hi, Guys!
Any news on this one?
Had this since this year’s January, when I installed the brand new CCR2004-16G-2S+.
I just reinstalled from scratch (major infrastructure change), and still have empty hosts table, and the infamous:
error.
Running 7.14 with same firmware.
Did you manage to find the culprit?
Thanks!
PS: updated to 7.16.1 (with same firmware also), hosts list now running ok, export also smooth. Will keep you posted!
