CCR2004-16G-2S+ shows wrong cpu mhz
This router should be 1700MHz according to the datasheet.
Or did i got the fast one?
Cheers,
Harry
[admin@x] /system/resource> print
                   uptime: 4m25s
                  version: 7.16.2 (stable)
               build-time: 2024-11-26 12:09:40
         factory-software: 7.15
              free-memory: 3764.3MiB
             total-memory: 4096.0MiB
                      cpu: ARM64
                cpu-count: 4
            cpu-frequency: 2000MHz
                 cpu-load: 0%
           free-hdd-space: 107.0MiB
          total-hdd-space: 128.0MiB
  write-sect-since-reboot: 26
         write-sect-total: 22263
               bad-blocks: 0%
        architecture-name: arm64
               board-name: CCR2004-16G-2S+
                 platform: MikroTik
Nominal CPU frequency is 1700MHz. But it’s possible to overclock it by setting /system/routerboard/settings set cpu-frequency=. Nowdays default setting is auto which allows ROS to scale frequency up or down depending on CPU core load. Sometimes this doesn’t work too well (it takes sone time to scale up and during that period of time router performance lags somehow).
I checked it, winbox doesn’t show that option.
CLI kind of the same:
[admin@x] /system/routerboard/settings> set cpu-frequency=1700
input does not match any value of cpu-frequency
[admin@x] /system/routerboard/settings> set cpu-frequency=2000
[admin@x] /system/routerboard/settings> set cpu-frequency=auto
Running export doesn’t show any changes to the default.
I guess its a cosmetic bug.
If you use
set cpu-frequency= and then TAB
what options do you get ?
Also check settings in /system/device-mode … I think you have to enable routerboard property to change cpu frequency setting … just don’t know which particular ROS version started to require that (could be it’s 7.17).
I get zero options. It like it did not press TAB.
That’s a good one.. but it seems i can not see the values. Maybe this is from v7.17 and later.
I’m running v7.16.2
[admin@x] /system/device-mode> print
  mode: enterprise
I’m running v7.16.2
Then yeah, you’re locked by default.
/system/device-mode/update routerboard=yes
beware, you will be forced to reboot - it tells you to unplug power or press button, but pressing button will reboot.
After the reboot, you will have settings available in /system/routerboard/set.
And if you do /system/device-mode/print, it will say something like:
         mode: enterprise
  routerboard: yes
Hi
I have upgrade and change the device mode.
But nothing really change still the wrong value and no way to adjust it.
Cheers,
Harry
[admin@MR1] /system/device-mode> print
                 mode: advanced
     allowed-versions: 7.13+,6.49.8+
              flagged: no
     flagging-enabled: yes
            scheduler: yes
                socks: yes
                fetch: yes
                 pptp: yes
                 l2tp: yes
       bandwidth-test: yes
          traffic-gen: no
              sniffer: yes
                ipsec: yes
                romon: yes
                proxy: yes
              hotspot: yes
                  smb: yes
                email: yes
             zerotier: yes
            container: no
  install-any-version: no
           partitions: no
          routerboard: yes
        attempt-count: 0
[admin@MR1] /system/device-mode> /system/res
resource     reset-configuration
[admin@MR1] /system/device-mode> /system/routerboard/print
       routerboard: yes
             model: CCR2004-16G-2S+
          revision: r3
     serial-number: x
     firmware-type: al64
  factory-firmware: 7.15.2
  current-firmware: 7.17
  upgrade-firmware: 7.17
[admin@MR1] /system/device-mode> /system/resource/print
                   uptime: 2m46s
                  version: 7.17 (stable)
               build-time: 2025-01-16 08:19:28
              free-memory: 3782.0MiB
                      cpu: ARM64
                cpu-count: 4
                 cpu-load: 1%
  write-sect-since-reboot: 37
         write-sect-total: 40492
               bad-blocks: 0%
                 platform: MikroTik
You can’t set CPU frequency like this?
/system/routerboard/settings/set cpu-frequency=auto
(or press before entering auto to see possible values)
It seems unable to modify the CPU frequency.undefined
