What is difference among CCR2004-16G-2S+ and CCR2004-16G-2S+PC other than later has cooler fan?
Is that fan essential difference?
Form factor and cpu clock speed
Yes, because for work correctly on passive cooler, the CPU is underclocked.
So among those two CCR2004-16G-2S+ is generally better choice? I like passive cooling but that is not critical for decision.
May I have liberty to ask about comparision with CCR1016-12G? It has a lot more cores, but slightly slower CPU and less RAM than CCR2004-16G-2S+. Targeted purpose is handling two internet links, queues, NAT, lots of firewall rules,
Don’t forget, the PC version is missing the USB port :-/
That does not concern me, just networking capabilities, so right now doubt is among CCR2004-16G-2S+ and CCR1016-12G.
CCR1016-12G has even less features bud 16 cores. I have no experience when number of cores matters more than clock speed or memory.
Better 1.700,00€ 4 times, or 1.200,00€ 16 times?
Apparently is better the latter…
But if you can receive only 1 time the money, you choice only 1 time 1700 or 1 time 1200?
The problem is what you need to do with that device.
If the operation you need can’t be done by multicore, better the faster with less cores.
Notice: the CCR1016 do not have any SFP port.
