does anyone know the oid values to monitor the CCR2004 temperatures?
iso.3.6.1.4.1.14988.1.1.3.10.0 is not working for this model
The temperature value is provided by SFP modules. If your device does not have attached SFP modules that can provide temperature values, it won’t be shown in health, and you will not be able to use OID .1.3.6.1.4.1.14988.1.1.3.10.0
I have sfp modules and I can see in system health several motherboard cpu and plain temperature readings.
The following are the ones that I can see related to temperature in System-Health:
board-temperature1
board-temperature2
cpu-temperature
temperature
What version of RouterOS you have?
On 6.46.8 and 6.47.9
RouterBOARD Temperature
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlTemperature.0
(1.3.6.1.4.1.14988.1.1.3.10.0)
Processor Temperature
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.mtxrHlProcessorTemperature.0
(1.3.6.1.4.1.14988.1.1.3.11.0)
/sys healt print oid
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrOptical.mtxrOpticalTable.mtxrOpticalTableEntry.mtxrOpticalTemperature.X
(1.3.6.1.4.1.14988.1.1.19.1.1.6.X)
x = interface number
Temperature of SFP module (if provided)
system health oid returns
temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
cpu-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
fan1-speed: .1.3.6.1.4.1.14988.1.1.3.17.0
fan2-speed: .1.3.6.1.4.1.14988.1.1.3.18.0
but none of them return anything in the dude or snmp walk
I ended up using [ros_command(“/system health print”)] for now to show the values
ros_command(":put [/system health get value-name=temperature]")
yes I know I could limit the value, thank you anyway.
At least this way I will be showing all values.
I will use the first option to trigger an event
