I have enabled the command /system/routerboard/reset-button/set enabled=no, but the fan keeps spinning wildly, and I cannot access the system. Resetting does not work, and Netinstall cannot find the device even after following the resetting instructions. Could you please advise the MikroTik technical team on how to restore normal usage
Have you connected a console cable and started a serial terminal emulator? Maybe followed by a power cycle?
In Routerboard settings you can set "try-ethernet-once-then-nand".
Then reboot (power off/on).
That should allow you to use netinstall.
I am unable to access the system now, and the reset operation has no effect. The fan is making an unusually loud noise
Currently, the two power lights for the LED lamp are on, while the USER light is on and off intermittently
Looks like bootloop.
And someone disabled the reset button ... how unfortunate.
Serial console should help.
Thank you all. The reset has been successful. I have a question: why does disabling the reset-button cause system damage? Logically, when the reset-button is disabled, the button should lose its effect, and the system should operate normally. How can we use this feature to prevent the device from being reset
I doubt disabling that reset button had anything to do with that bootloop.
That bootloop usually indicates a kernel panic or so ...
As an admin you have to decide:
disable reset button AND make sure you have console access.
Or do not disable the reset button and use a locked cabinet.
But don't close all gates and then complain you can not get in anymore.
