CCR2004 internal voltage
Can CCR2004 be powered directly to the board using 24 volts?
Others CCR usually have written on the board 8-56v, so they can be powered ranging from 8v up to 56v, but this model (CCR2004) only have written12v.
I know could use the PW48V-12V85W power supply, but it’s hard to find this model in Brazil at this moment.
My suggestion to Mikrotik is to deliver this model with one AC and one DC power supply from factory.
Did you ever find anything to do this:
I’m looking at https://www.amazon.com/EPBOWPT-Converter-Regulator-Voltage-Transformer/dp/B07V6X6L89/ref=pd_ybh_a_208?_encoding=UTF8&psc=1&refRID=2NBNXMRCR1P702T02JT3
to power a CCR2004 from a 24V source.
What I’m stuck on finding is something like the screw terminals( https://i.mt.lv/cdn/rb_images/1749_l.jpg) that come with the pw48v_12v85w to replace the AC input. to @least make it look like I didn’t hack it together.
