CCR2004 SFP+ on 2.5GBPS
I have an ONT leox with fiber in and a 2.5gbe port out that should go to the router.
I need this device in my configuration so I can’t go through an ONT SFP+ module (the CCR doesn’t handle a number of things in relation to my operator).
So I come to my main question. Some equipment with SFP+ port only works in 1/10gbits.
Can the SFP+ ports of the CCR2004 work in 1/2,5/5,10gbits?
Thank you!
This depends on the SFP Module you choose if they support multi-gigabit speeds (2.5Gbps)
I would recommend the Wiitek SFP+ to RJ45 Copper Modules for mikrotik as they support those speeds and are less :fire: hot then the mikrotik SFP+ module.
