Hi everyone,
I've read the detailed test thread by sacdepomme51 about the CCR2004-1G-12S+2XS splitting a single VXLAN flow across two CPU cores, causing 18–25% out-of-order packets on encapsulation. I understand this is a hardware/software behavior that couldn't be fixed with RPS, queue settings, or RouterOS version changes in that test.
Before I finalize my design, I want to ask about my specific use case, because I haven't seen it covered directly.
My scenario:
I'm building a small VXLAN/EVPN fabric for a CCTV deployment.
100 cameras across 20 locations.
2 Route Reflectors and 8 Leaf switches, all using the CCR2004.
The design follows the standard EVPN VXLAN model: OSPF is used for the underlay to advertise VTEP loopback addresses, and MP-BGP EVPN is used for the overlay to exchange MAC/IP bindings. The 2 CCR2004s acting as RRs only reflect EVPN routes; the 8 Leafs (also CCR2004) are VTEPs responsible for VXLAN encapsulation/decapsulation.
The traffic is UDP video streams going to a central recording server.
The bandwidth is very low – even with all cameras per Leaf, it's only tens of Mbps. I'm not worried about throughput. I'm worried about packet ordering.
My question:
For UDP video, many decoders and recording servers treat out-of-order packets as lost packets – they don't buffer and reorder. So that 18–25% figure isn't "25% slower," it's potentially "25% of packets discarded," which could mean stuttering, frozen frames, or gaps in recording.
Does anyone here have real-world experience using a CCR2004 as a VXLAN VTEP for video/CCTV specifically? Even at low bitrates, does the reordering translate to visible degradation in the recorded stream? Or does the low packet rate (compared to the 9 Mbit/s test) somehow mitigate it?
I'm not looking for "don't use it" – I already know the test results. I'm looking for someone who has actually tried it with video and can say whether the stream survived or not. If the answer is "it stutters even at 2 Mbps per camera," that's valuable information. If someone has a camera setup working, I'd love to hear the details.
Ultimately, I just want to make sure if this device is fine to run in such environments.
Best Regards
