RouterBOOT booter 7.12.2
CCR2116-12G-4S+
CPU frequency: 2000 MHz
Memory size: 16 GiB
NAND size: 128 MiB
Press Ctrl+E to enter etherboot mode
Press key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 7.20.4 (stable)
MikroTik Login: stage2_loader v3.63
Memory repair completed within 226 uSecs
DDR ECC static poisoning address: (0x1e0000)
DDR ECC static poisoning address: (0x1e1100)
SPD I2C Address: 52, offset 0000(0)
DRAM ch 0: 8GB
SPD I2C Address: 53, offset 0000(0)
PHY init error (8040007F)!
DX0: Read DQS Gate Error, Failing ranks bitwise 0x01
DX1: Read DQS Gate Error, Failing ranks bitwise 0x01
DX2: Read DQS Gate Error, Failing ranks bitwise 0x01
DX3: Read DQS Gate Error, Failing ranks bitwise 0x01
DX4: Read DQS Gate Error, Failing ranks bitwise 0x01
DX5: Read DQS Gate Error, Failing ranks bitwise 0x01
DX6: Read DQS Gate Error, Failing ranks bitwise 0x01
DX7: Read DQS Gate Error, Failing ranks bitwise 0x01
DX8: Read DQS Gate Error, Failing ranks bitwise 0x01
al_ddr_init(1) failed!
ddr_init_ch(1) failed!
