I’m posting my support ticket here in case someone else has the same problem and is googling (or better yet, knows what’s going on)…
Symptom
We have a VPN configuration where we connect to two routers over IPSEC then build a GRE tunnel, then do OSPF over the gre tunnels so that we have redundant vpn uplinks. When running 7.15.3 everything works fine, but then we upgrade to 7.16.2, 7.17.2, 7.18.2, or 7.19rc1 we can send traffic through the tunnel egress from the CCR2116-12G-4S+ but ingress traffic is has a lot of TCP retransmissions, TCP DUP ACK, and generally doesn’t work.
Here is how the config works:
add frame-types=admit-only-vlan-tagged name=bridge port-cost-mode=short vlan-filtering=yes
add fast-forward=no mtu=1500 name=loopback port-cost-mode=short
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=60 name=isp use-peer-dns=yes user=pppoeuser
/interface gre
add allow-fast-path=no clamp-tcp-mss=no !keepalive local-address=.96.237 mtu=1472 name=gre1 remote-address=.96.235
add allow-fast-path=no clamp-tcp-mss=no !keepalive local-address=.96.236 mtu=1472 name=gre2 remote-address=.96.253
/interface vlan
add interface=bridge name=vlan25 vlan-id=25
add interface=bridge name=vlan71 vlan-id=71
add bridge=bridge interface=ether2
/interface bridge vlan
add bridge=bridge tagged=ether2,bridge vlan-ids=71
add bridge=bridge tagged=ether2,bridge vlan-ids=25
add address=.200.14/30 interface=gre1 network=.200.12
add address=.201.14/30 interface=gre2 network=.201.12
/ip ipsec peer
add address=x.x.x.x/32 name=peer_1 profile=profile
add address=y.y.y.y/32 name=peer_2 profile=profile
/ip ipsec policy
add dst-address=.96.253/32 peer=peer_1 proposal=proposal protocol=gre src-address=.96.236/32 tunnel=yes
add dst-address=.96.235/32 peer=peer_2 proposal=proposal protocol=gre src-address=.96.237/32 tunnel=yes
/routing ospf interface-template
add area=backbone-v2 auth-id=1 auth-key=“” cost=10 dead-interval=4s disabled=no hello-interval=1s interfaces=gre1 networks=.200.12/30 type=ptp
add area=backbone-v2 auth-id=1 auth-key=“” cost=300 dead-interval=4s disabled=no hello-interval=1s interfaces=gre2 networks=.201.12/30 type=ptp
/ip firewall mangle
add action=change-mss chain=forward in-interface-list=vpninterfaces new-mss=1000 passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=1001-65535
add action=change-mss chain=forward new-mss=1000 out-interface-list=vpninterfaces passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=1001-65535
There is obviously more but you get the idea:
IPSEC tunnel to two hosts, GRE Tunnel over to those hosts using loopback addresses on each end, GRE interfaces have a /30 point to point network, OSPF turns on GRE interfaces to pass the routes.
On 7.15.3 this works fine no problems:
% scp test.bin hostinvlan71:
test.bin 100% 58MB 8.4MB/s 00:06
On 7.16.x 7.17.x 7.18.x 7.19rc1 same thing gets to 255KB and stalls:
test.bin 0% 255KB 1.2KB/s - stalled -^
If I copy a file to the CCR2116 over the VPN performance is fine, if I copy a file to a host on the other side of the CCR2116 then things stall after 255KB.
We are not using hardware routing:
/routing> /interface/ethernet/switch/print
Columns: NAME, TYPE, L3-HW-OFFLOADING, QOS-HW-OFFLOADING
NAME TYPE L3-HW-OFFLOADING QOS-HW-OFFLOADING
0 switch1 Marvell-98DX3255 no no
We don’t have any queues other than default.
“/queue export” returns nothing.
Also note I’m running 1000 MSS to ensure this is not an MTU issue which is confirmed in packet captures.
