CCR2116 Getting some problem
The MikroTik CCR2116 router is experiencing an intermittent issue where all interfaces stop/not working and appear to become disabled. When router hard rest the router restores normal operation. Additionally, accessing the router via the console port and manually enabling the interfaces also resolves the issue. We would appreciate assistance in identifying the root cause and recommending a permanent solution.
There can be several reasons.
You shoud post your configuration for review, instructions here:
Forum rules - #5 by gigabyte091
Depending on how often this happens, you might want to use a script via scheduler to run daily (say) at 2:00 AM or so to reset the interfaces as a temporary work-around.
I would additionally start a ticket with Mikrotik support.
I am unable to upload the configuration file because the attachment feature is not working on my side. Could you please advise me on an alternative way to share the file?
Post between Code quotes < / >
Did you even read that post which was linked by Jaclaz ? Details how to post are in there.
It does not involve an attachment.
