Some users complaint the slow network, we had use ping to test it, they are no any packet lost found, but use the Wireshark to capture the data,we had use btest to do the bandwidth test from PC to CCR2116, if the bandwidth over 200M with mode =TCP and Direction = both , it will found the “TCP Out-Of-Order” in Wireshark, anyone can help?
But there are default interface queue’s active. TAB “Interface Queues” under Queues
in MT Help:
All RouterBOARDS have default queue type “only-hardware-queue” with “kind=none”. “only-hardware-queue” leaves interface with only hardware transmit descriptor ring buffer which acts as a queue in itself. Usually, at least 100 packets can be queued for transmit in transmit descriptor ring buffer. Transmit descriptor ring buffer size and the number of packets that can be queued in it varies for different types of ethernet MACs.
in MT Help:
