CCR2116 v7.1.3, CCR2004 v7.1.2, CCR Reboot when queue simple over 700 entries
CCR2116
The effect that randomly after entering the queue simple tab with about 1500 entries, it causes a reboot (log: kernel failure in previous boot),
If I do not enter queues system not reboot.
OK works with about 650 entries. Over 700 queue simple entries CCR has a reboot at winbox entry into queue simple.
I put the queue simple baze into CCR2004 and the effect is exactly the same. Soft 7.1.2
Any updates on this issue?
We are experiencing similar symptoms any update or workaround?
ROS updated to newer version?
This is one of our biggest towers so had to wait until midnight, I’m almost there and will then upgrade to newest version. Currently on V7.2 which in fact I did not realize the version was that old and I do apologize for that.
No need to apologize :slight_smile:
i have tested 7.2.3 with ccr2116 working well with thousands of simple queues
9 hours without reboot, thank you guys hopefully its the last of that.
Thanks chechito for confirming.
What’s new in 7.2.2 (2022-Apr-28 21:01):
*) queues - improved stability in large list of queue scenarios;
What’s new in 7.3 (2022-Jun-06 11:38):
*) queue - allow to set higher limits than 4G;
*) queue - display warning for CAKE type in simple and tree setups when “bandwidth” parameter is configured;
*) queue - improved stability in large list of queue scenarios;
What’s new in 7.6 (2022-Oct-17 13:55):
*) queue - improved stability for CAKE type queues;
Tell your secretary to read the changelogs from time to time.
:laughing: If only I had one :laughing:
Been smooth sailing for almost 4 days now.
Again thank you for the help.
