CCR2216-1G-12XS-2XQ Crashing and Throughput Issues?
We’ve been looking to implement a CCR2216 for a while now possibly to replace our current main gateway. We’ve been doing some testing and have been noticing some issues with crashing and how much throughput said device can take. We’re using a 2216 and a 2116 to test throughput capacities and whether they’d do the job we’d expect them to on our network. The 2116 has no problem pushing TCP/UDP packets to the 2216 but as soon as we try to push packets from the 2216 it pegs at 15% CPU usage and is barely pushing through 5Gb. After about 15 minutes or so the router completely crashes and does not give any detailed information in the logs as to what might be going on. We’ve gone through and updated to latest ROS7 to eliminate any possible issues due to firmware but still have no luck. I’ve seen one other person have an issue with a firewall issue but were purely testing this on a closed environment. We thought maybe faulty equipment but, the other 2216 we have does the exact same thing. Are we doing something wrong on our end that’s limiting it’s potential? Any input would be appreciated!
