CCR2216 Bridge and HW3 Routes
Hello everyone, I would like to ask a question, an example of a scenario like the one in the image.
2 Internet LINKs, and in the example a CGNAT router and a PPPoE Client router.
In the 2216, for good CPU usage, and use of Hardware Offload L3.
Should I create a bridge, activate vlan-filtering, and now here comes my question, should I only put the interfaces that are going to my CGNAT and PPPoE or should I put the Internet Links as well? Both the links as well as the cgnat and PPPoE are interconnected via VLAN. And if so, if I should put the WAN interfaces, that is, the Internet Links in the bridge, should I disable the HW3 of these interfaces? Or should I put them as:
suppress-hw-offload yes in the routes I receive?
