Both models have the same L3 HW-Offloading capacity?
I know that the 2216 model has faster ports, but apart from that difference, and since they have the same processor, their L3-HW-Off performance is identical?
While both CCR2216 and CCR2116 have the same CPU, their switch chips are different: 98DX8525 and 98DX3255, respectively. Both routers provide near-to-wire-speed hardware routing. However, CCR2216 has significantly more hardware memory and, therefore, can hw-offload more routes/hosts/connections/etc.
hank you very much, it is clear then that we should buy the 2216.
