CDMA-EVDO USB-modem and PCi386-based routerOS v 3.27
Hi, comrades)
What I must to do after I plug in usb-port my modem AnyData ADU-310A
(skylink operator). I`m trying to have internet through this modem. sorry my bad english(
Try a search for 3G on the forum or on the MikroTik WIKI.
There are several examples and information on config.
But forst, make sure your router “sees” the device.
Look under system/resource/USB see if it is lested.
Look under system/ports (should show as a USB serial port (see docs on setting the bit rate etc)
Look under PPP if is there, you can begin setting up the PPP interface. if not double check the port config..
If still no go then send a “supout” to support..
(Look at the mail screen in winbox.. It is marked “Make Supout.rif”)
Good luck..
