CELOT usb cdma
i want to have request if you have drivers for the usb celot coma/evdo modem
http://www.celotw.co.kr/product03.asp
please advise as i would like to integrate it onto a 493G
regards
LM
I’m not sure forum has drivers for 3G device.
If you have this device in stock, install MikroTik RouterOS 5.7 on your router, plug 3G card and check support.
Contact MikroTik support (support), if card is not listed between ports (/port print).
Hello.
I have modem CELOT CT-680
System RouterOS 5.14
Has executed a command/port print but the modem in the list is not present.
Earlier I established modem Any Data ADU-500A and all worked. But it any more is not issued.
Whether you can help with connection CELOT CT-680?
I am afraid, support in region (Kiev, Ukraine) will not help me.
