Centralized backup script
backup.pl:
#!/usr/bin/perl -W
use Net::Telnet;
use Net::FTP;
use Mail::Sendmail;
use Benchmark;
$workdir = "/somedir/backup/";
$time1=new Benchmark;
$count=1;
($Second, $Minute, $Hour, $Day, $Month, $Year, $Weekday, $DayOfYear, $IsDST) = localtime(time);
$RealMonth = $Month + 1;
if ($RealMonth<10)
   $RealMonth = "0" . $RealMonth;
if ($Day < 10)
  $Day = "0" .$Day;
 if ($Hour < 10)
  $Hour = "0".$Hour;
 if ($Minute < 10)
  $Minute = "0" .$Minute;
 if ($Second < 10)
  $Second= "0".$Second;
$Fixed_Year = $Year +1900;
open(CFG, "$workdir/Backups.cfg") or (print "Can't open config file\n");
while($line = <CFG>)
 if($line =~ /#.*/)
  else
     if($line=~ /USR::/i)
         ($junk,$username)=split("::",$line);
          chomp $username;
     if($line=~ /PWD::/i)
       ($junk,$password) = split("::",$line);
	      chomp $password;
	 if($line =~ /Email::/i)
         ($junk,$Email) = split("::",$line);
         chomp $Email;
	 if($line =~ /ListFile::/i)
         ($junk,$LF) = split("::",$line);
         chomp $LF;
	   if($line =~ /Dir::/i)
         ($junk,$DIR) = split("::",$line);
         chomp $DIR;
         #print "$DIR\n";
	   if($line =~ /Log::/i)
         ($junk,$Log) = split("::",$line);
         chomp $Log;
         #print "$Log\n";
close(CFG);
open(logfile, ">>$workdir/$Log");
open(FH, "$workdir/$LF") or (print logfile "Can't open the list file\n");
#open(logfile, ">>$workdir/$Log");
print logfile "\n";
print logfile "$Fixed_Year/$RealMonth/$Day/$Hour:$Minute:$Second\n";
system("rm -rf  $workdir/failed_backup.txt");
$i = 0;
loop:
 while($line = <FH>)
   Errmode=>'return';
   Input_log=>"input.log";
   if(($line =~ /^#.*/)||($line =~ /^\s$/))
   else
      $i = $i + 1;
      ($IP, $Name) = split(":", $line);
      chomp($Name);
	  print logfile "#".$i."\n";
      $t = new Net::Telnet ( Timeout=>30, Errmode=>'return');
      print "$count\n";
      $count++;
      if($t->open($IP))
        print "open $IP - Telnet\n";
        $t->login($username, $password);
        print "@output\n";
        print "logged in\n";
        $cmd = "file remove \[find name\~\"\\\\.backup\\\$\"\]";
        $t->print($cmd);
        $cmd = "file remove \[find name\~\"\\\\.rsc\\\$\"\]";
        $t->print($cmd);
        $cmd = "system backup save name=".$Name."_"."$Fixed_Year$RealMonth$Day\n\n";;
        #print "$cmd\n";
        $t->print($cmd);
        sleep(2);
        #@output = $t->waitfor('/>/i');
	$cmd = "export compact file=".$Name."_"."$Fixed_Year$RealMonth$Day\n";
        $t->print($cmd);
	sleep(2);
	$fullfile = $Name."_"."$Fixed_Year$RealMonth$Day.backup";
        $Lfullfile = $DIR.$fullfile;
		$fullfile1 = $Name."_"."$Fixed_Year$RealMonth$Day.rsc";
        $Lfullfile1 = $DIR.$fullfile1;
        $F = Net::FTP->new($IP, Debug=>1, Timeout=>120, Errmode=>'return');
         if($F)
            print "open $IP - FTP\n";
            $F->login($username, $password)or goto loop;
            $F->binary or goto loop;
            $F->get($fullfile,$Lfullfile) or ((print logfile "Can't get $fullfile\n")and(goto loop));
	    $F->get($fullfile1,$Lfullfile1) or (( print logfile "Can't get $fullfile1\n")and(goto loop));
            $F->quit;
            print logfile $i . " - ";
            print logfile $IP . " - ";
             print logfile "OK\n";
            sleep(3);
            print "OK\n";
                 $t->print($cmd);
                 sleep(2);
                 $t->print($cmd);
                 sleep(2);
			$t->print('quit');
         else
            print logfile " FTP Error - $IP\n";
            print "Error\n";
            open(EL, ">>$workdir/failed_backup.txt") or (print logfile "Can't open the failed_backup.txt\n");
            print EL  "\n" . " FTP Error - $IP\n";
            $a='2';
      else
         print logfile "\n" . $i . " - " . $IP . " - Failed\n";
         print "Error\n";
         print EL "\n" . $i . " - " . $IP . " - Failed connect via Telnet\n";
         $a='1';
        # email("Telnet", $IP, $Email);
     print $a;
     if (($a=='1') or ($a=='2')) {
     system(`mail -s \"Backup report\"  mail\@domain.org\ < "$workdir/failed_backup.txt"`);
close(EL);
close(FH);
close(logfile);
sub email {
use strict 'refs';
my($refa, $refb, $Mailadd) = @_;
$Body = "$refa failed for $refb";
print "$Mailadd\n";
%mail = (
   To => $Mailadd, From => 'mail@domain.org', Subject => 'Mikrotik Backup Failed' , Message => $Body
$mail{Smtp} = 'smtp.domain.org';
if(sendmail %mail) {print logfile "mail sent\n";}
else {print logfile "Error sending mail. $Mail::Sendmail::error \n";}
print "\n\$Mail::Sendmail::Log says: \n", $Mail::Sendmail::log;
$time2=new Benchmark;
$timebenchmark=timediff($time1, $time2);
print "Time", timestr($timebenchmark);
	exit;
Backups.cfg:
USR::admin
PWD::somepass
Email::mail@domain.org
ListFile::router_list
Dir::/somedir/backup/
router_list:
1.1.1.1:GW01_1
2.2.2.2:GW02_1
3.3.3.3:GW03_1
Suggestions for improvement are welcome…
