Centralized PPPoE server
i’m lame in mikrotik.
i have rb1100 with 3 rb433ah and want make centralized pppoe server. all my links is on station-wds, rb1100 all ports is bridged. in this moment i have pppoe server on all rb433ah and have radius manager3.8. this solution working propertly.
but
now, i trying make centralized pppoe server with EoIP,but with out result :frowning:. i don’t know how.
pls help me
ditch the wds use mpls or eoip to to bridge your links so u can run bridge station mode
u can either just plug ur rb433’s to a switch or just plug them into each port on the rb1000 lose the bridge there you dont need any at all on the ppp box
and put a pppoe server on each interface or one if u go with a switch then turn off the ppp servers on the 433’s and justbridge the
wireless interfaces or tunnel interfaces depending on which way u end up going theres tutorials on how to setup mpls bridges on the mikrotik wiki site best way to go i have found resource wise anyway :slight_smile:
so u would have gateway—>pppoeserver<–cable–>4b433AP bridge ethernet to wireless---->client station with pppoe client
or gateway—>pppoeserver<–cable–>rb433bridgemode mpls <----->rb433stationmode mpls bridged to AP—>clients etc
