Centrelized Controle
Hi
I Have 5 Routerboard- RB951Ui, then i need to use as AP, to Expand Wireless over the all Office.
I Need to Centralize all Setting, like a Console, If a change somenting then can update in all APs, eg: Passworsd.
Thanks in Advance of all Sugestion .
SM
Unfortunately at the moment this is possible only with wireless configuration. If you want to synchronize configuration in other sections, then you have to sue some external tool/script which connects to router and executes same command on all of selected routers.
