/certificate - certs issued on 6.44.2 triple-up their subject-alt-names upon signing
Certificate shenanigans again, RouterOS 6.44.2 CHR.
I start off with a completely empty certificate system:
[me@myendpoint] /certificate> print
Flags: K - private-key, D - dsa, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
 #          NAME              COMMON-NAME            SUBJECT-ALT-NAME                                         FINGERPRINT
I create a CA and self-sign it:
/certificate add key-size=4096 days-valid=3650 trusted=yes key-usage=key-cert-sign name=MyCA common-name="My CA"
sign MyCA
All good so far:
 0 K   A  T MyCA              My CA        f5432231f8be7d2a7a5...
I create a certificate for the SSTP server:
add name=myendpoint.example.com common-name=myendpoint.example.com subject-alt-name=IP:192.0.2.1 key-usage=tls-server key-size=4096 days-valid=365
Again, all good so far:
 1          myendpoint.exa... myendpoint.example.com IP:192.0.2.1
Then I sign this server cert with the CA:
sign ca=MyCA myendpoint.example.com
And this happens:
 1 K    I   myendpoint.exa... myendpoint.example.com IP:192.0.2.1                                             c5ca3f3f91f9e9ef632...
                                                     IP:192.0.2.1
                                                     IP:192.0.2.1
What on earth is happening with the subject-alt-names???
Cheers!
Strangely, this appears to get worse with time - just ended up with eighteen SANs!
Fresh install of RouterOS CHR, no clue as to what’s causing this…
This is fixed already in the testing release channel and the fix will also be included in the next stable build. Sorry for any inconvenience.
What’s new in 6.45beta22 (2019-Mar-29 08:37):
*) certificate - fixed SAN being duplicated on status change (introduced in v6.44);
Looked everywhere but in the Beta release notes :smiley:
Many thanks for the heads-up Emils - that was steadily driving me nuts!
Cheers!
