Certificate Creation for OpenVPN
Hi All,
I have RB7851G with v6.17 installed.
I want create certificate for are openvpn connection.
When i start to create a certificate i get the message template
[admin@MT1] > certificate create-certificate-request
template:
what should i do ?
i use this tutorial.
http://wiki.mikrotik.com/wiki/OpenVPN_Configuration_Step_by_Step
thank you very much
mandragora
See this:
http://wiki.mikrotik.com/wiki/Manual:Create_Certificates
I recommend to you use this for quickly creating certificates:
http://www.selfsignedcertificate.com/
Then you can import it to rOS and use it on OpenVPN
HTH
M.
thanks to all.
great usefull tipps and works for me.
thx
mandragora
grate!!!
remember, you can give me karma if the tip helps you. :wink:
M.
