Certificate Import - OVPN Client connection.
Hi!
Could anyone point me in the right direction - I would like to connect to a OpenVPN server using RouterOS (Router 443 3.20).
I cant seem to correctly import certificate.
I have tried the command line and the GUI. Any help will be gladly appreciated as I have read trough the Wiki and User Manual - seems like there is very limited literature on the topic…
Thanks.
Adolph.
Hello ,
I have the same problem. It’s seems to be a bug … After import CA and key :
Flags: K - decrypted-private-key, Q - private-key, R - rsa, D - dsa
0 QR name=“cert1” subject=C=LT
It shows as QR , but must be KR.
Only one solutions i found out : backup , downgrade to 3.13 and again apdate to 3.22 .. :frowning:
Regards,
Hi Shellton;
Thanks for your help, will go through your procedure and let you know.
Regards;
Adolph.
I am having the same problem. However, 3.13 also gave me a Q instead of a K on a Crossroads device. I am trying 3.16 now, and 3.17 works on x86 devices for sure. A rollback to 3.20 on the crossroads did NOT help.
This is very confusing.
can you sloved this ?
i have this problem too , who can help me ,
