Certificate problem v6
I have everything working under v5.26 but on v6.12 no luck.
I have import the certificate and got the KT flag.
I have it enabled on the hotspot profile and on www-ssl service but every browser gives a warning for untrusted connection when try to login to the hotspot through https.
Have anyone got it working under v6?
Please give some info here.
Thank you
why did the browser give you that warning? about what is it complaining? signed by an non trusted ca? or you certificate is for a different hostname as the one of your hotspot.
Hi
This the the message from mozilla
Peer’s certificate has an invalid signature. (Error code: sec_error_bad_signature).
Thanks for your time
sound the certificate is corrupt. which ca issues the certificate? does other browsers show the same/similar error?
If its corrupted isn’t strange that it works on 5.26?
I have bought it from rapid ssl
IE gives: There is a problem with this website’s security certificate
Chrome gives: Cannot connect to the real xxxxxx.xxxxxx.com
Something is currently interfering with your secure connection to xxxxxxx.xxxxxxx.com (where xxxxx is the domain).
you’re right. i thought you reimported it after upgrade and your file get broken while uploading. what about other 6.x versions? newest version i run is 6.11 so far no problems with certificates
Is the KT flag what I want on v6? because on v5 was KR. I haven’t made it to work on any v6
 > /certificate print
Flags: K - private-key, D - dsa, L - crl, C - smart-card-key,
A - authority, I - issued, R - revoked, E - expired, T - trusted
 #         NAME               COMMON-NAME              FINGERPRINT
so KT sounds like something you want
Is it possible if I give you remote access to have a look on my setup?
Since its working on your setup?
i don’t know if this is possible. have you tried a different certificate? maybe a selfsigned
