Chain 0 and 1 with CPE's SISO
Bear with me guys, im working with RB912UAG-5HPnD and in this example im using in a small pop clients with OLD CPE’s SISO. ok, can i enable in RB912UAG-5HPnD chain 0 and chain 1 and use in some clients CPE’s the horizontal polarization and in other clients CPE’s use vertical polarization in the same POP RB912UAG-5HPnD at the same time ? im asking this because i noticed in RB912UAG-5HPnD that using the SCAN tool i found less Stations working at chain 1 and could be better work with less interference with ?
Thank you.
You can use stations with different pol. with no problem. You see more APs in Vpol because most of them are in Vpol. Stations can’t be found in scan mode.
Hello Inox, thanks you for reply, i dont know if im right and i would like to ask if
CHAIN 0 = horizontal and CHAIN 1 = vertical ?
thx
I found this using Scan tools, this isnot station ?
Those are AP’s as you can see on some of them at the radio name. In station mode the radio dont emit ssid so you can’t see them at scan.
You can see clients with snooper.
