Challenge using the RB760iGS
RouterOS 7.23.1 on RB760iGS / hEX S.
Goal:
IKEv2 certificate VPN to FortiGate dial-up hub.
Remote LAN is 192.168.125.0/24.
Need VPN-visible NAT addresses 1.1.5.x for PLC/HMI access.
Working:
IKEv2 certificate tunnel establishes.
Phase 2 establishes with:
MikroTik policy: 1.1.5.0/24 -> 192.168.130.0/24
FortiGate selector: 192.168.130.0/24 -> 1.1.5.0/24
MikroTik has:
1.1.5.1/24 on bridge
192.168.125.1/24 on bridge
Confirmed working:
MikroTik ping 192.168.130.1 source 1.1.5.1 succeeds.
Problem:
FortiGate ping 1.1.5.110 source 192.168.130.1 enters IPsec tunnel, but MikroTik NAT rules never count packets.
Tried:
dst-nat:
src-address=192.168.130.0/24
dst-address=1.1.5.110
to-addresses=192.168.125.110
src-nat:
src-address=192.168.125.110
dst-address=192.168.130.0/24
to-addresses=1.1.5.110
Also tried full netmap:
1.1.5.0/24 <-> 192.168.125.0/24
In both cases:
IPsec SA counters increment, but NAT counters and connection tracking do not.
Can RouterOS policy-based IPsec perform NAT-LAN style translation for decrypted inbound traffic, like 1.1.5.110 -> 192.168.125.110?
If yes, where must the NAT be applied? Firewall NAT, mangle, raw, mode-config, policy template, or a different IPsec design?
Interestingly enough I found that the issue was not just the MikroTik, but the FortiGate as well. While making the IPsec tunnel on the FortiGate side, the IPsec tunnel actually created a route for the virtual IP 1.1.5.0/24 but it's "distance" was 15 and the static route that I had created for the same connection had a "distance" of 10. So, the FortiGate was trying to use the closer one. I deleted the one I made and part of it was correct.
I also discovered that i created my NAT rules incorrectly because I had the source IP under the source IP address lists instead of the source IP address area (I simply overlooked it). I corrected that and then the entire connection went off without a hitch. Oh! I did have to turn off MikroTik FastTrack though. That did cause an issue when running remote connection software over the IPsec tunnel.
The default firewall rules have exceptions for ipsec traffic to not get fasttracked.
If you know the ports/protocols used by the remote connection software, perhaps you could just except them from fasttrack as well. (an accept rule for this traffic prior to the fasttrack rule)
