Change a Intel 3945abg notebook wireless card for an R52N
I appreciate if someone helps me in the following situation:
I have a Sony Vaio Notebook, model VGN-NR385E, that comes with a Intel 3945 wireless CARD. (Mini PCIe Card with U.FL-R-SMT connector).
My question is, since datasheet of R52N mini PCI Card says that connector is an uFL type, is it possible to change a 3945 card by a R52N?
Regards.
Daniel
how? can you see the difference?
there is just one problem, the size :slight_smile:
Thank you Normis,
By the way, you know any CARD with N support for this slot?
Daniel
http://shop.ebay.com/i.html?_nkw=minipci+express+802.11n&_sacat=0&_trksid=p3286.m270.l1313&_odkw=minipci-e+802.11n&_osacat=0
