Change a mikrotik USA version to international?
Good to all, I am in a complication, because I just bought a mikrotik the disc lite5 ac, but it is in the USA version and it has limited fractions, and here in my country I need them to be unlocked in order to use the equipment … .
What I am looking for is; Who could help me change my team to international?
I think, and I have read that it is done by direct reprogramming of the eeprom, could it be? some clue?
Hmmm, i have some capacs here bu they were delivered as International Versions. I simply went into the wifi settings and changed them to conform to Canadian allowable settings.
Can you not just go into wifi settings and set the Country and then apply the necessary changes??
Reverse is not possible.
USA version is hardware locked to USA region.
Hi
I have the same problem,
i bought Audience LTE from USA. Now i am in middle east and the country setting is locked to United states 3 and canada 2. i have tried with netinstall to put new software, the lock didn’t chang. In Kuwait there is no sdistributor.
Do you have any solution for my problem ??
…said ChatGPT more than two years after the event.
thank you
