Change ARP Rutine on TheDude
Hi you all,
I need to GET ARP table of one switch. Because this switch support ipNetToPhysicalTable instead ipNetToMediaTable (according RFC4293) i would like to change ARP routine to be showed on the Dude Config/SNMP/ARP screen report.
I think Dude is looking for OID 1.3.6.1.2.1.4.22.1.2 but i need to change/replace by OID 1.3.6.1.2.1.4.35
is that possible?
regards.
