Change channel
Hello!
Have bought a RB911G/AR9888 set, one is a master and one is slave, and set as bridge modus, and use channel 5500. But if I scan the area it find another antenna using channel 5500.
Can I only change the channel on the master?? And is it only to change under Wireless, double click on the Interface, change freq and push apply??
Regards
Kåre!
