change "credit limit reached" message
Hello
how can i change the message “credit limit reached” in the login page?
I want to translate it.
$(if error)
$(error)
$(endif)
<script type="text/javascript">
var error = "$(error)";
if (error == "credit limit reached") {
   document.write("your credit has expired.");
else {
   document.write("$(error)");
</script>
Where i need add this html code?
Regards
Yes you can i believe you have an HTML editor; note pad can do that
if (error == “abcdef”) {
document.write(“your credit has expired.”);
else {
document.write(“$(error)”);
Please. It possible to put pictures of the modified
