Hi ,
I have an question that can I change default configuration ??
for example , when someone click the physical reset button , my rb can reset to my custom default configuration??
Hi ,
I believe you can.
Your desired default configuration can be loaded via netinstall when installing the RouterOS.
Ohhh!!
I try some method in http://forum.mikrotik.com/t/new-rb951g-2hnd-bricked-solved-with-netinstall/70728/1
Thanks for your help ![]()
