I’m currently struggling with netinstall and changing the default config.
Can someone please share steps and simple example of the actual file which can be used with netinstall in order to replace default config. Like for example I want to have two vlans on eth1 and dhcp client activated on one of them… This config should be activated when hardware reset or /system restore-configuration
Thank you
