Can anyone please tell me how do I change the default ip of 192.168.88.1 to 192.168.1.1 on the crs106 5port Sfp switch
/ip->addresses, select 192.168.88.1 entry, modify the options as required, and hit save. Be sure that network is correct too.
Thanks for the reply it worked can you tell me this are the Sfp ports on this downlink ports like can I run my internet into the back and then feed my switches with Internet through there uplink ports
Can You Clarify you question?
I have a MikroTik crs106 5port Sfp switch can I connect my main Internet to this switch first then run Sfp fiber modules to each of my switches so modem - router - Sfp switch - passing internet connection to my other switches using there Sfp uplinks
