Hi is there a way to change C:/Program Files/Dude/data folder for syslog?
I have the same question.
Does anyone have any way to change the syslog file location ?
This is a big problem for partition ![]()
Does anyone know any way to change syslog file location ?
I have the same question…it’s a big problem for partition ![]()
Not that I know of but you might be able to use passthrough to another syslog server or syslog program on the same computer which will basically be a duplicate, then you could set the dude syslog to very low disk space.
